Davek0974
Posts: 286 Joined: Sat Feb 01, 2014 2:07 pm
Post
by Davek0974 » Mon Feb 15, 2016 3:46 pm
I am building a small CNC router/mill to go alongside my plasma table, I heard a rumour there was a speed & feed calc plugin - does it still exist??
Also, what would be the recommended post for a generic mini-mill running Mach3 ??
Many thanks
Dave
Posts: 3683 Joined: Thu May 11, 2006 8:12 pm
Post
by Les Newell » Wed Feb 17, 2016 4:22 pm
Terry, it looks like the attachment is missing in your feeds and speeds thread. Could you try re-uploading it.
Dave, for your machine the 'Mach3' post should do the trick.
Vmax549
Posts: 641 Joined: Mon Nov 09, 2009 5:55 pm
Post
by Vmax549 » Wed Feb 17, 2016 5:09 pm
Hiya Les, OH it is there you just have to login before you can see it (;-) Even then sometimes it is there and sometimes it is NOT there.
I just checked it and it IS there for me.
(;-) TP
Davek0974
Post
by Davek0974 » Wed Feb 17, 2016 5:43 pm
Ok, got that, however i cant use it because it does not fit on my screen believe it or not!
I have a widescreen laptop and the form is too tall to show all the boxes at the bottom and does not have scroll bars
Oh well
Vmax549
Post
by Vmax549 » Wed Feb 17, 2016 10:18 pm
THAT must be a METRIC thing problem
I need to see IF I can figure out converting teh other one to Scam. UNLESS Les wants to give it a whirl.
Most times he has to answer 500 questions before I get done so really it would be a lot less work for him IF he just did it himself.
TP
Vmax549
Post
by Vmax549 » Wed Feb 17, 2016 10:55 pm
DAVE go to the link NOW there should be a WIDE version posted. Try that one
(;-) TP
Davek0974
Post
by Davek0974 » Thu Feb 18, 2016 7:21 am
Thanks, that just about fits now, usable anyway
Vmax549
Post
by Vmax549 » Fri Feb 19, 2016 11:19 pm
HIYA Dave, that chart is simply a JPG picture of it. The picture is in teh Dir for the plugin. You can reedit it any way you need and it will auto fit itself back into teh window. You can make it wider or shorter to suit your screen.
I will work on the other soltion it is a better function overall. That version was just a test to see if I could do it.
(;-) TP
