Peck Drilling issue,
Maybe i misunderstand the conceot, but drilling i always have problems with. I have these settings and always get rapid movements where they should be feed see
Cut depth set to 15mm
peck depth 5mm
Peck retract 2mm
Plunge rate 50mm/min
N0170 G01 Z-5.000 F50.0
N0180 G00 Z-8.0000
N0190 Z-4.0000
N0200 G01 Z-10.000
N0210 G00 Z-18.0000
N0220 Z-9.0000
N0230 G01 Z-15.000
N0240 G00 Z10.0000
I would have thought that the operation would have gone
set feed rate -5mm deep, retracted to-3mm at rapid, rapid back to -5mm and start drilling again at 50mm/min, to -10mm, then rapdi back to-8mm, rapid back to -10mm, drill at set feed to -15mm and be done. is there a setting i have wrong?
this is set um on a milling machine with mach3. Les can you help me figure this out.
peck depth 5mm
Peck retract 2mm
N0180 G00 Z-8.0000
N0190 Z-4.0000
N0200 G01 Z-10.000
N0210 G00 Z-18.0000
N0220 Z-9.0000
N0230 G01 Z-15.000
N0240 G00 Z10.0000
Post Processor is Mach3 Rotary (edited)
Mach3 4th axis rotary post processor
For milling/routing with the PlasmaRotary plugin
- peck hole test.tap
- (1.25 KiB) Downloaded 183 times
This looks like a bug in the rotary helper. I'll fix it properly for the next release but you can fix your copy yourself. Run SheetCam as administrator (right-click on the SheetCam shortcut->run as administrator). Now go to Options->plugin options->RotaryPlasma and click on the 'edit macro' button. In the editor go to File->open and open the RotaryHelper file. In there replace function OnRapid() and function OnRapid2() with the versions below:
function OnRapid()
--post.Text(" R ex = " .. endX .. " ey = " .. endY .. " ez = " .. endZ .. "\n")
local tx = endX
local ty = endY
local tz = endZ
if(endX >= 1e17 or endY >= 1e17) then return end
sc.QueryDll(qrySETXSTART, endX, dllId)
sc.QueryDll(qrySETYSTART, endY, dllId)
sc.QueryDll(qrySETZSTART, endZ, dllId)
if(endZ >= safeZ) then
local z
if(endZ > 1e17) then
z = sc.QueryDll(qryGETSAFEZ, 0, dllId) + safeZ
endZ = 0
else
if(currentY > 1e17) then
z = sc.QueryDll(qryCHKEND, endY, dllId)
else
z = sc.QueryDll(qryCHKEND, currentY, dllId)
-- rotaryVals.z = z
if(z > rotaryVals.z and currentX < 1e17 and currentY < 1e17) then
endX = rotaryVals.cx
endY = rotaryVals.cy
endZ = z + endZ
DoRapid()
endX = tx
endY = ty
endZ = tz
rotaryVals.z = z + endZ
else
sc.QueryDll(qrySETZ, endZ, dllId)
rotaryVals.z = sc.QueryDll(qryGETZ, 0, dllId)
if(ignorePierceHeightMove and endZ < currentZ and endZ == pierceHeight) then
endX = tx
endY = ty
endZ = tz
return
OnRapid2()
endX = tx
endY = ty
endZ = tz
function OnRapid2()
--post.Text(" R2 ex = " .. endX .. " ey = " .. endY .. " ez = " .. endZ .. "\n")
currentX = rotaryVals.cx
currentY = rotaryVals.cy
currentZ = rotaryVals.cz
endY = sc.QueryDll(qryRAPIDY, endY, dllId)
endZ = rotaryVals.z-- + endZ --sc.QueryDll(qryGETZ, 0, dllId) + rotaryVals.z + endZ
endA = sc.QueryDll(qryGETA, 0, dllId)
DoRapid();
rotaryVals.cx = endX
rotaryVals.cy = endY
rotaryVals.cz = endZ
N0180 G00 Z-4.0000
N0190 G01 Z-10.000
N0200 G00 Z-9.0000
N0210 G01 Z-15.000
N0220 G00 Z10.0000
Fixed thanks heaps for that.
While i've got you how do i fix this? everything works fine just does this on start up.
N0180 G00 Z-4.0000
N0190 G01 Z-10.000
N0200 G00 Z-9.0000
N0210 G01 Z-15.000
N0220 G00 Z10.0000
- Untitled.png (37.59 KiB) Viewed 6461 times
- log.txt
- (3.03 KiB) Downloaded 201 times
