I use Vectric Vcarve pro to design my parts. The files are only saved as .crv
How do I convert these .crv files to .DXF in order to import into sheetcam
for my plasma cutting ?
vcarve .crv file into .dxf for sheetcam ?
Re: vcarve .crv file into .dxf for sheetcam ?
You can export to dxf straight from vcarve, you just need to do an export instead of a save
ok, now its a .dxf file, so now I have to do a post processing to make it into a .tap file before Firecontrol sees it as a .tap file
How do I do that.
Thanks for your input so far.
How do I do that.
I got it, been a very tiring day, finally used Sheetcam to convert it to tap file
Thank you
Tom
Thank you
Tom
