Sluggish duplicating parts Development ver
SeanP
Post by SeanP »
I'm sure this has got worse in last few updates Les, same thing on house pc as well.
I used to be able to get 3 or 4 sheets of parts onto one job file before it slowed down, even a sheet with 15 parts seems to start getting jumpy when nesting parts, tried a comparison using tng version and that does seem better, looking at task manger, cpu usage is getting high when moving parts around, any ideas?
10mm.job
(115.99 KiB) Downloaded 133 times
Re: Sluggish duplicating parts Development ver
Do you have full tool paths enabled? It's in the nesting right-click menu.
SeanP
Post by SeanP »
Thanks Les, yes I did have that enabled, it does help with that off, but there still seems to be a fair difference between between tng and dev versions when selecting parts laid out over say 2 sheets with 260 parts in total, dev is a lot slower for some reason.
By the way new features are superb, search in quick load and parts count are spot on!
I did a quick video to try and show what I mean.
https://youtu.be/_nEF9FiKyxM
That does look a bit much. I'll do some profiling and see if I can figure out what is going on.
SeanP
Post by SeanP »
That seems better now Les.
Really liking the new custom shortcut keys, great how you can just use a single key as well, apart from mode/nesting can't seem to get it to change to a single key.
Good work, thanks.
You can't use a single key. Say for instance you mapped the key '5' to the nesting mode. Now every time you press 5, even if you are in the middle of editing a number, it will switch to nesting mode.
SeanP
Post by SeanP »
I see what you mean there, but saying that I have most of the other set to a single key and get around it easy enough, numbers you can use the keypad numbers and map top row numbers and with letters only time it seems to cause that problem is renaming a part, which can be got around by using caps.
Alternatively use the function keys. You can use them without ctrl or alt. If I remember correctly F1 is hard mapped to help so you can't use that one.
