layers missing in dxf file
christian99x
Post by christian99x »
Hi,
what is wrong with the attached dxf file - not all layers are showing up in sheetcam!
thanks
C.
507_moutingbracket_verbindungsteil.dxf
(63.14 KiB) Downloaded 166 times
ArchieF
Post by ArchieF »
I see 3 layers :
Layer 0
Layer fase
Layer rastscheibe
Are this all ?
Edit: CAD program shows M3 and M5 thread but not SheetCAM
Richard
ArchieF
Post by ArchieF »
In the Drawing Options Dialog check the option ' use points for drilling '.
Then the missing layers appear.
Richard
christian99x
you don't see a layer "aussen" or "kontur"? neither in sheetcam nor in your cad software?
ArchieF
Post by ArchieF »
I can see both layers in the layer list of the CAD but trying to show them fails so as if they would be empty.
All other layers I can activate or deactivate
Rich
christian99x
I have this issue again and again. On another computer the import works without problems.
I am also missing the metric/imperial option in the scaling of the drawing import dialog - I think it is a problem of the dxf import plugin....? Am I missing any libraries....? PLEASE HELP....
C.
ArchieF
Post by ArchieF »
Do you have the correct extension *.dxf selected in the file open dialog ?
Do you have unchecked from the menu :
Options -> Application Options -> Annoying dialogs : Import Drawing ?
Richard
christian99x
This did the trick - great! Thanks a lot!
C.
