Les...
How can I setup SC so it outputs arcs and circles as small line segments rather that G02/03 arcs?
Circles as segments
You can edit the post processor .
From the Post documentation file :
ArcAsMoves(Tolerance)
Perform the current arc as a series of short linear moves. This should only be called from the onArc() event.
Tolerance is the maximum deviation in millimetres from a true arc.All other parameters are optional. Reducing Tolerance increases the number of line segments generated.
Richard
Richard
