I have the rotary axis parallel the x-axis and want to do a regular rotary milling job.
Which pp must I use to convert Y in A in plain gcode converted arcs to line segments?
Richard
Which PP to use ?
Hi Richard,
I don't have a post for that. Does the A axis need to be scaled or do you just need to change the Y to A?
Go to Options->machine->post processor and slect the 'Minimum g-code noarcs' post. No click on the 'edit post' button and replace every occurrence of " Y" with " A". Save the post and go back to Options->machine->post processor. Make sure you have the edited version of the post selected.
Note that this does not scale the A axis at all. It gets a bit more complicated if you need to scale A.
Okay,
modified the 'Minimum g-code noarcs' post and added some mathematics.
The output is a file with Y-values converted to A-angles and scaled to the diameter you have to define as variable via an operation.
Attached is a job file, a screenshot of my backplotter to show the result and the modified pp.
As always use it on your own risk and use a backplotter to verify the code before working with it on the machine !!
Richard
@ Les
the 'Minimum g-code noarcs' post has an error in the function OnInit() :
if(scale == metric) then
post.Text (" G91\n") --metric mode <==must be G21
else
post.Text (" G90\n") --inch mode <== must be G20
Richard
@ Les
else
- Minimum G-code no arcs Rotary Axis.scpost
- the PP
- (3.57 KiB) Downloaded 215 times
- the screenshot
- SheetCamByLes.jpg (25.83 KiB) Viewed 2346 times
- SheetCamByLes.job
- the job file
- (66.32 KiB) Downloaded 254 times
Oops. I'll fix that for the next release. Thanks for letting me know.the 'Minimum g-code noarcs' post has an error in the function OnInit() :
else
Some machines use G20/G21 and some use G70/G71. I have absolutely no idea why I used G90/91!
