Hi Les, Just loaded V-6.1.74 and the auto load plugin for Mach 3 seems broken. This happened with the previous version as well.
I'm running Mach 3 V-3.043.077 if that makes a difference.
Thanks, Steve
TNG 6.1.74 plugin
Re: TNG 6.1.74 plugin
Hi Les, I've tried uninstalling the plugin , reinstalling Sheetcam, reinstalling the plugin, restarting multiple times... it still says the plugin is broken when Mach starts.
What else can I try?
I would really like this to work again because it saves a LOT of mouse cliks...
Thanks, Steve
Thanks, Steve
AARGH! I can't believe how that keeps creeping back in. If you install the stable version of SheetCam the plugin will work again. You can have both stable and dev on your computer at the same time.
