6-1-62 question
6-1-62 question
Hi Les, just trying the new version and I get a message when Mach3 opens saying "Plugin DLL Defectice" , This seemed to happen the first time opening Sheetcam after the update. Is it related... or a Mach issue.
Thanks, Steve
Thanks, Steve
Re: 6-1-62 question
A bit of an update. I did a system restore to a point just before loading V6.1.62 and the auto load plugin works fine but when I install V 6.1.62 Mach3 gives the defective plugin warning, so I assume it's something in V 6.1.62?
But, other that that the latest improvements work fine!
Thanks again Les for a great program!
Re: 6-1-62 question
Hi Steve,
That's odd. I just tested it here and I didn't have any problems. I have just uploaded an update for a different issue. Could you give that a try.
Re: 6-1-62 question
Les, sorry but still broken. Steve.
Re: 6-1-62 question
Further update, after I load either V.62 or V.63 I get the broken .Dll message and if I load an earlied version (the latest one I have is V.53) it still gives the broken .DLL message when Mach3 opens. The only way to fix it is with a system restore back about a week ago and then Mach opens with out an error.
Re: 6-1-62 question
This is the DLL error that comes out in version 62/63
- 2º error.png (4.53 KiB) Viewed 5363 times
- 1º error.png (3.03 KiB) Viewed 5363 times
Re: 6-1-62 question
Could you go to c:\mach3\plugins and delete the SheetCamRemote file. Now reinstall SheetCam. Does that fix it?
Re: 6-1-62 question
Still no go... Actually, I uninstalled 6.1.63 , restarted, still get the message. The only way to get auto load working is with a system restore back to before 6.1.62 or 6.1.63 was installed.
Re: 6-1-62 question
Could you go to c:\mach3\plugins, right-click on the SheetCamRemote file and select 'properties'. Could you tell me the exact size of the file.
Re: 6-1-62 question
12.0 KB (12.288 bytes)
- Sheetcam properties.PNG (294.67 KiB) Viewed 5344 times
Re: 6-1-62 question
I figured it out. I was accidentally distributing a debug version of the dll. This will only run if you have Visual Studio installed. It ran fine on my computer but not on most others.
Re: 6-1-62 question
Hi Les, Looks good on this end, working well!
Thanks again for a great program!
