Color in function of the area
Another feature that if there is not already, and that I would return to profit, would be to be able to function in a color automatically assigned to a certain area of ​​the drawing, such as passing a programmable surface value the program checks the yellow below that value blue. Already exists this function?
I'll explain but google translator does not help me ... when I make a check design to large areas of one color and areas small (holes) another color, in this way, with two tools at different speeds, I make sure that the work to be done at speed from the table Hypertherm large areas and reduced by 40% on small areas. I tried it and it works, wondering if it was possible to implement an automatic function that in complex designs by assigning a minimum area value the program gives the DXF automatically two colors.
