Hello Les,
included with this post is a job file and even if i think my rules a OK, it posts thc off on the first 2 holes, then doesnt on the rest. This has happened a couple of times.
My rules are a little complicated because
1-i still want the arc ok before move
2-m10p1 stops the torch without a stop in motion.
thank you
thc not posting in g-code.
I'm trying to learn the ins and out's of these new rules to, what I did notice there though is:
Should you not have start code: thc off in the small circles rule?
I don't just understand the last rule on the small holes (on leadin set feed to 100% then after 1.27mm output code: thc off) will that not confuse matters, I unticked that.
Running that through in the simulator had thc turning off ok.
I see you are using the stop torch in motion code as well, I guess that little slowdown right at the end coincides with the stop torch code, interesting to see the different ways of using that.
