Here is a new plugin that lets you Veiw your Gcode files.If you are like me you have 1000 files . You remember what it is it looks like BUT can't remember what you called it. This works like the other veiwers.
Just unzip it into your plugins directory then restart Scam. It will appear under Plugins menu.
(;-) TP
Scam Gcode Veiwer
Thanks For the catch on the FORM NAME. I forgot to change it. Yes the code is similar but performs different functions.
Here is the updated PLugin with the correct form name in the screen veiw.
- GcodeVeiw.zip
- (2.42 KiB) Downloaded 921 times
